How to merge 2 halves of an image contained within 2 separate folders + repeat (2 image sequences)?
I have two folders of image sequences. Folder 1 contains images for the left hand side of the frame. Folder 2 contains images for the right side of the frame. Each image in folder 1 pairs with a corresponding image in folder 2 and I want to merge the two.
Is it possible to batch process the merging of these ‘halves’ into a third folder?
