Activity Forums Adobe After Effects How to maximize workflow when using dual xeon processor
  • How to maximize workflow when using dual xeon processor
    Posted by Serj Bato on July 20, 2007 at 6:08 am
    hey! I need some help. I have recently acquired a pc setup with dual xeon processor with 3 Gigs ram. how do i maximize the use of my processors in after effects 6.5 or 7 workflow? for example, when i started to ram preview a certain project of mine, it only uses 1 processor. i tried to avoid using Gridiron ’cause it beats the purpose of setting up a multiprocessor pc. help please. tnx
    Emre Tufekci s.o.a. replied 19 years, 2 months ago 3 Members · 2 Replies
  • Darby Edelen
    July 20, 2007 at 6:12 am
    [jres_bato] “for example, when i started to ram preview a certain project of mine, it only uses 1 processor. i tried to avoid using Gridiron ’cause it beats the purpose of setting up a multiprocessor pc. help please. tnx”
    …If you want to use multiple processors/cores then you need to either upgrade to CS3 or buy GridIron Nucleo. If you did either of those things then more RAM wouldn’t hurt either.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Emre Tufekci s.o.a.
    July 20, 2007 at 5:14 pm
    ” tried to avoid using Gridiron ’cause it beats the purpose of setting up a multiprocessor pc”
    I am not sure if you watched the demo for nucleo pro but with NP you can render and keep working at the same time. You can also assign # of processors to do certain tasks.You can tell it to render you timeline when you are idle or create faster previews. If you want you can also tell it to take over the machine completely and it will ride your processors like there is no tommorow.
    I use dual dual amd opteron w/nucleo pro and cant imagine a workflow without it.
    I hope this helps,
    Cheers
    Emre
    http://www.productionpit.com
    Boxx Tech PC, dual-dual AMD 2.0,4BG ram,Avidexpress HD w/Mojo,UVW-1800,DSR-25, Adobe production studio.
    “Creative cow is udder madness.”
