Activity › Forums › Adobe After Effects › How to maximize battery usage
  • How to maximize battery usage
    Posted by Xavier Paredes on October 31, 2018 at 8:10 pm
    I’m catching a plane tonight for a long flight and would like to wok while on the plane. Besides quitting all apps that I am not using, are there any other tips/tricks that can help prolong my battery charge?
    I know that many processes run in the background so I wonder if there’s any way to limit or quit them altogether? I will also make sure my screen brightness is just bright enough so as to save battery.
    Thanks for any tips!
    – Xavier
    Xavier
    Andrew Somers replied 7 years, 11 months ago 3 Members · 3 Replies
  • Blaise Douros
    October 31, 2018 at 8:18 pm
    Check under your seat–a lot of planes have AC outlets now.
  • Xavier Paredes
    October 31, 2018 at 8:23 pm
    Thanks. I did not know that!
    Xavier
  • Andrew Somers
    November 1, 2018 at 5:08 am
    I’d be surprised if a long flight didn’t have AC outlets, so you should be okay, BUT, to answer your question regarding quitting processes:
    You can use ACTIVITY MONITOR in the Utilities folder to look at what processes are running, which are using the most energy/CPU/Memory etc, and you can also force them to quit.
    Andrew Somers
    VFX & Title Supervisor
    https://www.GeneralTitles.com
