Activity › Forums › Adobe After Effects › How to mask a particle producer
  • How to mask a particle producer
    Posted by Bigmitch on November 28, 2007 at 9:32 pm
    I’m trying to produce a skywriting effect, so I’m using the built in Particle World III (I think) but I haven’t figured out how to mask off areas in the particle producer’s path. Is this possible?
    David Bogie replied 18 years, 10 months ago 3 Members · 3 Replies
  • Mike Derk
    November 29, 2007 at 2:27 am
    Have you thought about moving the generator to spell out the letters, and turning the gravity to zero so the particles won’t move?
  • Bigmitch
    November 29, 2007 at 3:44 am
    Hi Mike, thanks for the reply. I’m home now, so I found out I’m using CC Particle Systems II. I’m trying to turn the smoke on/off during a horizontal or vertical pass through the letters. I’ve tried simple masks, and animating the birth rate and max opacity attributes but it doesn’t really change anything. I hope I don’t have to make each and every letter segment a different solid/effect, that would be about a hundred!
    For each horz or vert “pass” of the producer across the screen I need to turn the smoke on and off up to 8 times.
    Any ideas welcome!
  • David Bogie
    November 29, 2007 at 6:27 pm
    Get on the phone right now and find someone you know and like who has Final Cut. LiveType and Motion both have a lovely animated font that is perfect for skywriting.
    However, your client may have some unreasonable expectations. You may need to find a very expensive 3D artist who can do this for you if you need to show the airplane or airplanes (modern skywriting is performed with 8 planes laying down dots of smoke) or if you need to show some of the smoke being disturbed by a passing aircraft.
    bogiesan
