Activity › Forums › Avid Media Composer › How To Map “Set Multichannel Audio” to Keyboard
  • How To Map “Set Multichannel Audio” to Keyboard
    Posted by Brian Steele on December 13, 2016 at 11:13 pm
    Editing Brothers and Sisters,
    I just started a feature on the newest version of Avid, and I’m trying to figure out how to map onto the keyboard, “Set Multichannel Audio,” so that I can press a key and turn a sound effect clip into stereo. In Avid Media Composer 8.6.4, you’d either right click or go to Clip > Modify > Modify Clip, then in the drop down go to Set Multichannel Audio, and change the clip to stereo from there. I can get as far as “Modify Clip” mapped to the keyboard, so I’m one step behind – what I’d ultimately like to do is press a key and voila, my SFX clip with 2 mono tacks becomes a stereo clip, that I can cut onto a stereo track on my timeline. Anyone have a solution? Thanks in advance…
    I’m running:
    Mac OS X 10.9.5
    2 x 2.66 GHz 6-Core Intel Xeon
    32 GB 1333 MHz DDRR3
    NVIDIA GeForce GTX 285 896 MB
    Brian Steele replied 9 years, 9 months ago 2 Members · 2 Replies
  • Trevor Asquerthian
    December 14, 2016 at 7:56 am
    Modify is as close as I’ve managed to get at the moment without macros (e.g. AHK)
    Even with macros it’s going to be tricky as there are warning pop-ups the first time you go to modify a clip then modify defaults to last parameter used
    Would be great to have presets that were keyboard mappable (e.g. 2xstereo 2×5.1 SMPTE)
    You could try filing a feature request at community.avid.com/forums but don’t hold your breath
  • Brian Steele
    December 14, 2016 at 10:21 pm
    Thanks for your response Trevor. I figured this would be a pipedream, but that’s a good idea, I think I’ll bring it up to the Avid forums.
