Activity Forums Maxon Cinema 4D how to map a photo image to the extruded edge panel of a spline?
  • how to map a photo image to the extruded edge panel of a spline?
    Posted by Sean Bowerman on January 20, 2012 at 1:25 am
    this is driving me nuts, i’m sure its super simple but i can’t figure it out.
    i’ve extruded a rectangular spline.
    i’m trying to map a colour to all the sides except one of the extruded panels. i’d like to map a photo to that. C1 and C2 are the front and back faces, is there a selection technique for the extruded sections?
    i’d also like to keep the extrude editable because i have to animate it… is this possible?
    apologies if this is something really obvious…
    Adam Trachtenberg replied 14 years, 7 months ago 3 Members · 3 Replies
  • Jack Cook
    January 20, 2012 at 1:13 pm
    Probably for this you need to make the extruded object editable. This will make a copy of it that has the sides and the two caps in it as children. Select this object, and the caps and choose Functions>Connect. Now it is one polygon object. At this point you can delete the other objects if you want, or hide them. Select the new object, go into polygon mode and select the faces that you want to put the material on. Set the selection as a saved selection and give it a name. Now put your material on the object and in the material tag, where it says “selection” put in the name of the selection you saved. The material will be mapped to only those polygons that are part of the saved selection.
    Jack
  • Sean Bowerman
    January 20, 2012 at 1:49 pm
    many thanks for your swift reply! i’m no modeller but i managed to follow this, and it works great. now i need to figure out how i can still animate the extrusion… any suggestions?
  • Adam Trachtenberg
    January 20, 2012 at 3:44 pm
    There’s a relatively cheap plugin called xspolyinstance that I’d recommend for this. What it does is create a polygonal copy of your nurbs object. That allows to you make polygon selections as you would with with a normal polygon object — and assign materials to your selections — but the object maintains a live connection to your nurbs object, so it will animate as you do the extrusion.
