Activity › Forums › Adobe After Effects › How to map a layer to inside of a large sphere and have camera inside it.
  • How to map a layer to inside of a large sphere and have camera inside it.
    Posted by Jaso Allen on January 2, 2007 at 11:52 am
    Hi there,
    I’ve got a background layer which i’d like to map to the inside of a large sphere so I can then bring a camera inside the sphere and aim it around looking at different spots.
    Is there an easy way to do this which I’m overlooking? I tried CC Sphere but I don’t think you can get inside it. Spherize is the closest i’ve come to faking it, but you have to mess around a lot more to make it look like im basically just slowly spinning inside a ball.
    Any suggestions would be greatly appreciated. Thanks a lot everyone.
    Sincerely,
    Jason Allen
    Serge Hamad replied 19 years, 9 months ago 4 Members · 6 Replies
  • Chris Smith
    January 2, 2007 at 9:34 pm
    Use the CC Environment effect. It’s part of the HD Cycore package. You’ll have to Google it yourself as it’s blocked from here.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Jaso Allen
    January 3, 2007 at 12:39 am
    Thanks for that guys.
    Thats what I was thinking basically.
    The only other thing i’m going to try is making a large cube out of 6 solids, putting a camera inside it and somehow using an adjustment layer with CC Lens to make it all look sorta roundish. It doesn’t have to be precise, it’ll be pretty blurred as a background to animations moving infront of it.
    Thanks for the help again Dave and Chris. You’ve both helped me before, I appreciate it again!
    Jase
  • David Bogie
    January 4, 2007 at 12:11 am
    There’s also 3D Assistants from, I think, Trapcode. You can import a whole bunch of layers and tell 3D assistant to map them into a sphere. Very cool. Not cheap.
    bogiesan
  • Serge Hamad
    January 4, 2007 at 5:59 am
    If you have Invigorator it would be a snap!
    Let me know if you have the plug and I will guide you through the process.
    Salut.
    Serge
    “InvigoMany” Available here:https://www.nyc-visual.com
  • Jaso Allen
    January 4, 2007 at 7:19 am
    Hi Serge,
    I do have invig, hadnt thought of that. A cube would be easy enough i spose. For a sphere do you start with a tiny radius circle and add a halfpipe edge?
    Also I havent tried going inside a model before. Will that work? and if so will my layer maps just be the same as I’ve set, except backwards given im looking from inside?
    Thanks a lot for the idea Serge.
    Jase
  • Serge Hamad
    January 4, 2007 at 4:01 pm
    Jason. What version of Invigorator do you have? And how many clips do you need to map?
    The method you described will give you a sphere, just make sure that your circle is 0.8 X 0.8 and that the faceting values are set to (0.01) to get a smooth sphere. The last value must be typed in, as the slider will only go to (0.1)
    Salut.
    Serge
