Activity › Forums › Maxon Cinema 4D › How to make Truss structures with Cinema 4D?
Posted by Guido Agüero on August 29, 2011 at 6:25 pmHello Folks!
I am trying to do in C4D Some “Truss” structures, I have to recreate some kind of stage but i have no idea of how to do some trusses properly.
I could say it is about using the cloner object with some cylinders but i still can not get it!
Any help would be appreciate. Thanks in advance!
I am using C4D R12.
Guido Agüero replied 15 years ago 3 Members · 5 Replies -
Greg Burrus
August 30, 2011 at 2:34 amHmm clonners would be first way to try it, which might still work well depending on what your going for.
Some other options might be to try the atom array object and mess with the setting so it doesn’t have the spheres at the points.
You also may want to look in to using the tracer. That combined with sweeps nurbs, circle and some splines might lead you to a interesting structure.
I vaguely remember seeing some plugin a files setup that would work well for this but I can’t seem to find it. If it if I do I will be sure to link it up.
hope this helps,
Greg
https://mogra.g2bproductions.com/ – Blog
https://g2bproductions.com/ – Portfolio -
Randy Johnson
August 30, 2011 at 9:03 am*Create the the shape you want with a cube or what ever.
*Add segments so it looks nice.
*Make it editable.
*In the functions menu select triangulate.
*Get a cylinder turn off caps make it smaller…
*Get a cloner object
*Set the cloner to object Mode (rather than linear)
*Change the Cloners distribution to EDGE
*Adjust the cylinder to fit right./Randy
Guido Agüero
August 30, 2011 at 2:32 pmHey! Thank you guys for this help!
It is a bit difficult for me understand English, but i am going to try this suggestions you gave me!
I am really a bit confuse about the steps you gave me Randy.
So if i get stepped i will let you know!!!
thank you very much guys for helping me!!!
Hey Greg, if you search on google “truss light structure” you will see what kind of structure i am talking about!!!
Really thanks!!!!
Randy Johnson
August 30, 2011 at 6:01 pmHere is the method I wrote.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
direct link: https://www.youtube.com/watch?v=V07n0iUXciI
/randy
Guido Agüero
August 30, 2011 at 6:06 pmMy Gosh!
Thank you very much Randy!!!
You make a mini tutorial for me!
Really thank you! i am more than graceful. And yeeeeeahhh you rock!!! This is a pretty quick way to do it!
I can understand it now clearly….
Amazing! Really thanks!
