Activity Forums Adobe After Effects How to make those news shiny edges?
  • How to make those news shiny edges?
    Posted by Thanh Le on April 2, 2016 at 5:00 pm
    I have seen the programes introduce on our national channel and really want to know how they make those shine (or flare) edge on the boxes?
    Thanh Le replied 10 years, 5 months ago 3 Members · 3 Replies
  • Jay Mueller
    April 3, 2016 at 2:04 pm
    Try optical flares by video copilot
  • Tudor “ted” jelescu
    April 4, 2016 at 11:36 am
    A easy and fast way of creating the effect you’re after is if you use CC Light Sweep on a graphic element. So if you design the tabs either separate in AI or using masks on a solid in AE, you can apply Generate/CC Light Sweep and then play with the Width of the sweep, the Edge Thickness and Intensity and you can animate the highlight by animating the center position. You can have the actual sweep be visible or you can turn the Sweep Intensity down to have just the edge appear.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Thanh Le
    April 4, 2016 at 2:15 pm
    Thanks Ted, I think i figured out how to make it using Optical Flare and CC Light Sweep. The result is briliant. Here is it:
    Thanks guys!
