Activity Forums Adobe After Effects How to make this text animation
  • Ivan Eldredge
    January 13, 2025 at 3:06 pm
    Hello Yuval!
    To recreate the text effect from your video, you can use the “Fade Up by Characters” Preset (Go to the Effects & Presets panel in After Effects, search for Fade Up by Characters under Animation Presets > Text > Animate In)
    Apply this preset to your text layer by dragging it onto the layer.
    To animate the character tracking, you can use a Tracking Animator (With the text layer selected, go to the Animate menu under the Character section in the Timeline, choose Tracking to add a tracking animator.)
    Adjust the Tracking Amount keyframes to create dynamic spacing changes over time.
    These combined techniques should help you achieve a similar effect. If needed, tweak the timing, easing, and properties in the Animator to match the exact behavior.
    Best,
    Ivan Eldredge G.
