Activity › Forums › VEGAS Pro › How to make the clips add to the project to automatically get croped to their last 30 seconds
  • How to make the clips add to the project to automatically get croped to their last 30 seconds
    Posted by Lord Porongus on December 21, 2016 at 10:59 pm
    Hey there! I’m basically a novice with Vegas Pro 14 and I’m in need of some help. I’m making a compilation video so I have these 90 clips that I have to add and then cut. From these 5 minutes long clip I only need the last 10 seconds of each.
    So my question is… Is there a way to set Vegas to automatically cut new added clips in a specific way? Or even select the clips in the project and cut them all at once?
    Lord Porongus replied 9 years, 9 months ago 2 Members · 2 Replies
  • László Kovács
    December 22, 2016 at 9:04 am
    As always, if it’s a repetitive tedious task, there’s a high chance that Vegasaur can help you.
    This is true for you as well :))
    That setup will keep only the very last 10 seconds of your selected events.
    After that, you can remove gaps, also doable with Vegasaur 🙂
    Best regards
    László Kovács
  • Lord Porongus
    December 23, 2016 at 4:55 pm
    I’ll check it out. Thanks!
