Activity › Forums › Adobe After Effects › How to make text take the shape of a container?
  • How to make text take the shape of a container?
    Posted by Hilary Tsai on January 12, 2019 at 6:00 am
    I want to make my text into the shape of a rectangle (just two words–one on top of the other), which fill up a mask but do not spill outside the bounds of that mask. It’s hard to describe what I mean; I need the text to look distorted, like it’s trying to bulge out of its container but maintains a rounded rectangle shape. Is there a way to achieve something like this in Ae? I’ve played a bit with spline paths and making text follow the splines; this is sort of a different, but related concept, I just don’t know how to do it. All suggestions are appreciated. Thanks!
    Hilary Tsai replied 7 years, 8 months ago 3 Members · 5 Replies
  • Kalleheikki Kannisto
    January 12, 2019 at 7:01 am
    The Warp effect sounds like a candidate for this.
    Senior Graphic Designer
  • Richard Garabedain
    January 14, 2019 at 3:51 pm
    Come on. I have seen the tutorial on this page several times…you convert the text to masks and animate that. be sure to set first vertex though…literally right click on a point of the mask and set as your first vertex
  • Hilary Tsai
    January 14, 2019 at 8:36 pm
    Thanks Richard! I wasn’t aware of those tutorials; I think I was not using the proper search terms what I seek. This solution is exactly what I needed.
  • Hilary Tsai
    January 14, 2019 at 8:37 pm
    Thanks Kalleheikki! I tried using the warp tool like you suggested, and it definitely gave me some cool results.
  • Hilary Tsai
    Thanks Dave! I think I will try adding some bulge on top of the warp effect.
