Activity › Forums › Adobe After Effects › How to make stars Twinkle on After Effects cs5?
  • How to make stars Twinkle on After Effects cs5?
    Posted by Aja Shapiro on February 22, 2011 at 1:05 am
    I have a background that’s full of stars and I was wondering if someone can give me a step-by-step process on how to make them look twinkle? I was told to use fractal noise, but I’m really having a hard time figuring it out.
    Darby Edelen replied 15 years, 7 months ago 3 Members · 4 Replies
  • Darby Edelen
    February 22, 2011 at 3:00 am
    [Aja Shapiro] “I was told to use fractal noise, but I’m really having a hard time figuring it out.”
    You’d need to create a layer that is just your stars, then apply fractal noise to that layer with the ‘Multiply’ blend mode, then animate the Evolution of the fractal noise.
    You’ll probably want to tweak the brightness and contrast of the effect as well.
    Darby Edelen
  • Michael Szalapski
    February 22, 2011 at 3:31 pm
    Or you could use a precomp that contains a layer with Fractal Noise animated as Darby suggests as a track matte for your stars. It kinda depends on what your background layer looks like.
    How did you create those stars?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Aja Shapiro
    February 22, 2011 at 7:34 pm
    @Michael
    I found the stars from google images, it already included the entire background filled with many different shapes of stars,and the sky as well. All in all I’m gonna try both of the suggestions, and see what happens.
    Thanks alot for both of your suggestions
  • Darby Edelen
    February 22, 2011 at 8:17 pm
    [Aja Shapiro] ” it already included the entire background filled with many different shapes of stars,and the sky as well.”
    In that case you’re going to need to create isolate the stars as I suggested. You will probably be able to pull them out from the other elements in the sky through a combination of masking and color correction effects.
    Darby Edelen
