How to make flat uv re map in ae?
Hello!
I’ve made a square plane in 3d space with camera on top, unwrapped it and made uv pass. Everything seems fine however when I apply texture to uv pass it gets significatly distorted. I saw example in https://vimeo.com/138778625 where flat TV surface was used for remapping and in video it worked okay.
How then to make flat re map surface?Here is what I have https://i.imgur.com/PpMA3UB.png. Even tried to use same size pictures
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
