Activity › Forums › Maxon Cinema 4D › How to make an object follow another object
  • How to make an object follow another object
    Posted by Amelie Lim on July 23, 2013 at 12:39 pm
    I wanna add an object but how do I make that object follow this spline ?
    https://vimeo.com/15773811
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Amelie Lim replied 13 years, 2 months ago 2 Members · 11 Replies
  • 11 Replies
  • Brian Jones
    July 23, 2013 at 3:31 pm
    that sort of thing would usually be done by using a SweepNurb to sweep a profile spline along another spline
  • Amelie Lim
    July 24, 2013 at 12:59 am
    Thank you for your response!
    I’m not sure o how to do that, but you mean like this?
    https://i43.tinypic.com/2cg0pdy.jpg
    by creating a sphere and dragging it under spline?
    I’m a bot confused. I have to create another spline? or can I just used the spline available?
    Your response is appreciated.
  • Brian Jones
    July 24, 2013 at 1:39 am
    you want the sphere to move inside the sweep? If so, take the sphere out of the sweep and add an Align To Spline tag to the sphere, then you drag the spline in the sweep (Spline.1) into the Align To Spline tag’s “Spline Path” spot
  • Amelie Lim
    July 25, 2013 at 1:10 am
    Yes, that’s what I intended. so that it looks like the sphere is moving with the nurbs.
    I already added an align To Spline tag to the sphere.
    but I am confused with the next step you mentioned.
    Please take a look:
    https://tinypic.com/view.php?pic=2hxrkib&s=5
    am I doing it right? if yes, it isn’t working.
    may I know what went wrong?
  • Amelie Lim
    July 25, 2013 at 2:09 am
    Please take a look:
  • Brian Jones
    July 25, 2013 at 2:57 am
    Here is an example with simple parts but it would work just as well with a more interesting spline etc.- just a circle spline and the flower spline to make the Sweep tube, and a sphere to follow the same circle spline used in the Sweep.
    6317_sphereinsweep.c4d.zip
  • Amelie Lim
    July 26, 2013 at 3:15 am
    I saw the file you uploaded. I tried to apply the similar technique, but it isn’t working.
    I have attached the file for your reference.
    6327_splineerror.rar.zip
    Inside the sphere’s align to spline tab, I have set the spline path to “spline.1”.
    but then, the sphere isn’t following the spline as expected. am I missing something here?
  • Brian Jones
    July 26, 2013 at 1:29 pm
    you have to keyframe the Position parameter in the Align to Spline tag or it won’t move along the spline (like the camera’s Align to Spline tag following the same spline)
  • Amelie Lim
    July 28, 2013 at 12:50 am
    May I ask where I can find the the Position parameter in the Align to Spline tag?
    I’m kinda new to cinema 4d. 🙁
  • Brian Jones
    July 28, 2013 at 8:00 pm
    when you click on the Align to Spline tag all it’s attributes show up in the Attribute Manager (that’s the stuff in the lower right corner of the interface) – that’s true for all things you click on
