Activity Forums Adobe After Effects How to make an object follow and interact with a path shape
  • How to make an object follow and interact with a path shape
    Posted by Fabricio Araujo on February 13, 2009 at 3:58 am
    I have a thin and long object and I wanna make it follow a determinated 3d path.
    The final result is make this object move like a snake, moving and bending according the path.
    Is there a solution for this or I will have to make it manually???
    Thanks.
    Fabricio
    Viacheslav Sasykin replied 17 years, 6 months ago 2 Members · 4 Replies
  • Viacheslav Sasykin
    February 13, 2009 at 1:47 pm
    There is a number of ways you can do it.
    You may want watch this tutorial first (by Maltaannon):
    https://maltaannon.com/articles/after-effects/cgsnake/
    then if you gonna have more questions ask here.
    Hope it helps.
  • Fabricio Araujo
    February 14, 2009 at 11:07 pm
    Thank you very much for youe attention, Viacheslav but is not exactly the result I was looking for.
    I cant create segments for the effect.
    I need to bend a thin and long image several times to create the effect I want.
    The moving is softer but I need to do it in the tree axis.
    To explain it better is just imagine a camera in the back of a snake following it movement… up, down, left, right and foward.
    I hope Id been good enough in this explanation.
    Hope you can help me!!!
    Thank you very much indeed!
    Fabricio Araujo
    February 15, 2009 at 11:02 pm
    If you want real 3D distortion/bending etc.applied to picture/video then you probably need something like Zaxwerks 3D Layer Warp or Forge Freeform (plug-ins for AE) or Boris Blue (standalone program/plug-in). May be Trapcode Form but I`m not sure if it can do what you want.
    On Alan Shisko`s blog you`ll find pretty good tutorial about Zaxwerks 3D Layer Warp, just search it.
    Good luck!
    February 15, 2009 at 11:14 pm
    If you want real 3D distortion/bending applied to your picture/video then you need something like Zaxwerks 3D Layer Warp or Forge Freeform (plug-ins for AE) or Boris Blue (standalone program/plug-in). May be Trapcode Form but I`m not sure if it can do what you want.
    There is a pretty good tutorial on Alan Shisko`s blog about Zaxwerks 3D Layer Warp, just search for it,
    Good luck!
