Activity › Forums › Adobe After Effects › How to make an even selection?
Posted by Ray Doll on December 28, 2011 at 9:35 pmThis has been bothering me to no end. What is the key combo to make an even selection? In photoshop its shift+drag.
Tero Ahlfors replied 14 years, 8 months ago 3 Members · 3 Replies -
Michael Szalapski
December 28, 2011 at 11:54 pmI don’t know what you mean by “an even selection”. In what context are you trying to do this particular selection?
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Ray Doll
December 29, 2011 at 5:06 amYour post is correct – it does. I have found the solution: in After Effects CS5.5, to make an an even selection you use shift drag, BUT you have CLICK first, THEN press SHIFT (unlike in Photoshop CS5.1 and most Adobe programs, where you hold shift FIRST, THEN click and drag.) The order of operation is crucial, because in Photoshop you would want to depress shift first, then release the mouse button (if you don’t do it this way, you risk messing up the selection). As far as I have figured out, in AE shift also deselects the layer or something silly like that, so shift then drag just ends up in frustration. However if you click, THEN shift, then drag, it works.
Phew.
