Activity Forums Adobe After Effects How to make a text come flying to the screen in 3D space (along a path)?
  • How to make a text come flying to the screen in 3D space (along a path)?
    Posted by Sebastian Lee on February 9, 2013 at 3:50 am
    So how do I make a text come flying pass the screen in 3D space, meaning at a distant the text appears very miniscule and as it gets closer to the screen it becomes bigger BUT it must follow a path I draw using the Pen Tool. I’m trying to make a countdown 3, 2, 1 and every numbers come flying towards the ‘camera’ or the screen, they must be of every seconds. This is too complex. need ur help thanks
    William Scholik replied 13 years, 6 months ago 3 Members · 3 Replies
  • Dan Conrad
    February 9, 2013 at 7:17 pm
    In your Text Layer there is a Path Options drop down. In there you can choose a path you want your text to animate on.
    @mographcandy
  • Sebastian Lee
    February 10, 2013 at 5:22 am
    Yes that one I know, but I’m asking how to do in 3D space???
  • William Scholik
    February 12, 2013 at 9:30 pm
    I’m sure there would be many ways to to this. I would just key the furthest point that you want the text and then the closest/past the camera. This will make a path for the text that you then can edit with the pen tool. I know it isn’t exactly using a path but you should be able to get the desired results.
