Activity Forums Adobe After Effects how to make a precomps lights show up?
  • how to make a precomps lights show up?
    Posted by Jeremy Webb on February 8, 2006 at 11:49 pm
    i brought a precomp that has a bunch of lights into my comp and expected the lights (or at rather the effect the lights had on the precomp) to carry through when i hit the collapse transformations button. but no workey. is there a way to make this happen?
    Roland R. kahlenberg replied 20 years, 7 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    February 9, 2006 at 4:43 am
    Ensure that the 3D switch for the precomp is on.
    RoRK
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
    February 9, 2006 at 4:58 am
    Argh! Forget about my previous post. Wha tyou can do is try not to click on the Collapse Transform switch. If that is not possible, then you can always copy the light layers in the precomp and paste it into the higher level composition.
    Thereafter, you will want to switch the ‘original’ lights so that AE doesn’t calculate it twice.
    HTH
    RoRK
    broadcastGEMs
