Activity Forums Boris FX Particle Illusion How to make a point size emitter larger?
  • How to make a point size emitter larger?
    Posted by Peter Wu on February 24, 2008 at 2:18 pm
    I want to make a simple lower third by running a star trail across the bottom of the screen. This is easy enough. However, the resulting trail is a thin horizontal line too thin to cover up text. How can I make it a thick horizontal line? If there is a way to change the point size emitter into a circle, a square, or a line, then I’m golden.
    I tried changing all the visible parameters but none of them affects the size of the emitter.
    I also have AE. The emitter size can be changed easily, but I thought with a preset star trail, it would be easier to make this lower third in PI.
    Elvis Deane replied 18 years, 6 months ago 2 Members · 1 Reply
