Activity Forums Adobe After Effects how to make a period (full stop) blink?
  • how to make a period (full stop) blink?
    Posted by Scyld on May 6, 2008 at 1:27 pm
    hi, i’m using the typewriter effect in CS3 and i’m trying to work out how to make the period at the end of the sentence blink for a few seconds while the user reads the text and the new text comes in to replace it. is there any easy fixes, or does this involve expressions?
    – apologies if this has been posted before…
    Mohit Singh replied 15 years, 2 months ago 6 Members · 9 Replies
  • 9 Replies
  • Mike Park
    May 6, 2008 at 3:04 pm
    why don’t you try keyframing the opacity. You could use an expression, but don’t need to. Just put the period on a seperate layer and animate the opacity
    best of luck
  • Scyld
    May 6, 2008 at 3:26 pm
    thanks. i was thinking of that, but i’ve got approx 50 different instances of text with blinking periods to do, so that’s 50+ layers to deal with… any ideas how to change the opacity of just the period using the text effect controls? i couldn’t figure out how to isolate the period.
  • Scyld
    May 6, 2008 at 3:38 pm
    makes sense. many thanks…
  • Paolo Ciccone
    May 7, 2008 at 1:00 am
    In your text layer with the period type “t” for transparency, Alt/Option click on the stopwatch to access the formula, enter this:
    x = Math.sin(time*10);
    if (x<0) 0 else 100
    You can use smaller multipliers for longer interval between blinks
    Paolo Ciccone https://www.paolociccone.com
    Hellriser Digital
    Santa Cruz, CA
  • Scyld
    May 7, 2008 at 1:24 pm
    that works great for the whole text, but how do i isolate the “.” ?
  • Paolo Ciccone
    May 7, 2008 at 3:24 pm
    Can you create a text layer just for the period?
    Hellriser Digital
    Santa Cruz, CA
  • Efe Aydal
    December 25, 2010 at 1:23 am
    Thanks a lot. I had the same question.
  • Ric Vieira
    May 19, 2011 at 3:04 am
    Wow, it works a treat! – absolutely genius.
    grazie mille!!
  • Mohit Singh
    July 20, 2011 at 10:33 am
    thats what v want sir. thanks a lot
