Activity Forums Boris FX Particle Illusion How to make a line in PI SE?
  • How to make a line in PI SE?
    Posted by Cyborg Commando on May 7, 2006 at 8:24 pm
    Hello
    Im trying to make a straight line in PI SE and the only way I know is to
    make 2000 number of emitters, is there a better way?
    I need the line to appear in steps I mean – — — —- etc
    not all at once so I can’t bring it as a texture.
    Cyborg Commando replied 20 years, 4 months ago 2 Members · 4 Replies
  • Alan Lorence
    May 8, 2006 at 7:19 pm
    I’m not sure what you mean by “make 2000 number of emitters”. Do you mean set the emitter “number” property to 2000? I’m also not sure what you mean by “line”. Do you want the particles to create a line as they move, or do you want a line of non-moving particles? If non-moving, just make a line emitter.
    Alan.
    wondertouch
  • Cyborg Commando
    May 9, 2006 at 9:27 pm
    Yes, I meant I set the emitter “number” property to 2000.
    Here is an example of the emitter
    https://www.polystash.com/non_relevant_files/line_example.avi
    but Im asking if there is a better way of doing this?
  • Alan Lorence
    May 9, 2006 at 9:40 pm
    How about this? I didn’t have to set “number” as high as you did.
    https://www.wondertouch.com/downloads/temp/cow/SE_line_sample.ipf
    Alan.
    wondertouch
  • Cyborg Commando
    May 10, 2006 at 7:39 pm
    Thank you for the respond but that’s not what Im looking for.
    Your emitter is creating a line from the point emitter (the yellow dot).
    Im looking for an emitter that will make the line as a trail, plus without the
    fade in and out in the emitter.
