Activity › Forums › DSLR Video › How to Make a dark scene without any Noise?
  • How to Make a dark scene without any Noise?
    Posted by Taha Kirmani on September 11, 2014 at 11:16 am
    Hi
    I am using Nikon D3200, I am trying to shoot a dark scene. The scene is so dark and there is minimal amount of light. I am shooting in manual mode and these are my settings. ISO 200, f/5.2, Shutter Speed 1/100.
    With all these settings i am getting so much noise in the scene. Kindly tell me how to avoid noise in the Dark Scene.
    Taha
    Samuel Drake replied 11 years, 12 months ago 2 Members · 1 Reply
  • Samuel Drake
    September 26, 2014 at 2:25 pm
    Try opening the aperture of your lens as wide as it can go. The lower the f stop number, the wider the aperture. f/2.8 is wider than f/5.2 and so on. Also try reducing your shutter speed to 1/50. 1/48 is the norm for cinema, but 1/50 is as close as your camera can get.
    Bear in mind that opening the aperture will cause a shallower depth of field, but this can be a good thing if you can control the focus. Not all lenses can open wide enough to eliminate noise in low light situations. I have a Nikkor 50mm f/1.8D lens and it is very good for low light at f/1.8. It won’t auto focus on a D3200 though, so you would need to do that manually. It takes some getting used to. At f/1.8 you would be leaving a lot more light get through to the sensor and could therefore try lowering your ISO to 100 which would reduce the noise even further.
