Activity Forums Apple Final Cut Pro Legacy How to make 5D 24p footage show up as 24p in FCP
  • How to make 5D 24p footage show up as 24p in FCP
    Posted by Jason Caridi on June 26, 2011 at 3:53 pm
    I set my sequence presets to ProRes 422 1080/24p and when I make a new sequence and then import my video, the setting tab under the sequence has quite a limited drop down menu for presets… and it shows 1080 24i instead. How can I be sure that my footage in a sequence is 24p? Thanks!
    Rafael Amador replied 14 years, 10 months ago 3 Members · 4 Replies
  • Everest Mokaeff
    June 26, 2011 at 5:14 pm
    Mark II 5D footage is 23.976 if you shoot in 1920 x 1080 24fps.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Jason Caridi
    June 26, 2011 at 6:19 pm
    Yes, I meant that. The editing timebase says 23.98, but the interlaced remains fixed
  • Everest Mokaeff
    June 26, 2011 at 8:46 pm
    So what’s a big deal? Ingest clips through L&T or otherwise, drag and drop them on time line. FCP asks to match sequence to clip, you say yes. That’s it. You have ProRes sequence that matches your Canon 5D clips. If you open sequence settings you’ll discover codec (Prores) and 23,976 fps (if you shot in 24 fps mode).
  • Rafael Amador
    June 26, 2011 at 9:25 pm
    [Jason Caridi] “I set my sequence presets to ProRes 422 1080/24p and when I make a new sequence and then import my video, the setting tab under the sequence has quite a limited drop down menu for presets… and it shows 1080 24i instead. How can I be sure that my footage in a sequence is 24p? Thanks!”
    Make sure the footage is checked as “NONE” on the Browser, then drop a clip in ANY sequence and let FC conform the sequence to the footage.
    rafael
    http://www.nagavideo.com
