Activity › Forums › Apple Final Cut Pro Legacy › How to make 16:9
  • Richard Harrington
    September 11, 2008 at 5:23 am
    Set your monitor to 16:9 and make sure clips were logged that way
    Then edit into a 16:9 sequence and if needed remove the distortion from the clips
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Kris A. wotipka
    September 14, 2008 at 6:31 am
    I was working with my my second 16:9 DVCAM project and forgot to set the capture setting to DV NTSC Anamorphic. So on playback everything was 4:3 squeeze. I figured out that you can check the anamorphic setting in the bin and it changes the attribute of the clip so that when it plays in the viewer, it is 16:9. I doubt that this sets the anamorphic marker in the original QT clip but it works inside FCP.
    Just my 2 cents. Hope it helps.
    kw
    kris@wotipka.com
    Image maker
