Activity Forums Adobe Audition how to loop for background noise
  • how to loop for background noise
    Posted by Bodybuildingbs on January 1, 2006 at 8:49 pm
    Hello
    I have a bowling alley scene and I want to add in background of a bowling alley..I have the sound clip but its woefully short..how do I make it into a loop for the duration of the scene?
    Willie Toth replied 20 years, 8 months ago 2 Members · 1 Reply
  • Willie Toth
    January 1, 2006 at 10:45 pm
    Jack,
    There are two ways you can do this, the easiest, but sometimes not the best way, is to right click on the track and go to LOOP PROPERTIES … In the upper left corner of the properties page you will see a small box that says ENABLE LOOPING, left click in the box and hit OK … Now if you go to the lower right hand corner of the clip LEFT CLICK & HOLD while draging to the right it will loop your clip for you … Drag until you get the legnth you want … Make sure that the begining and the end of the original track starts and stops where you want all the tracks to start and stop from … With this being background noise I would say that this is the best method to use ……….. WILLIE
