Activity Forums Adobe Premiere Pro How to link two audio tracks so that key frame work applies to both ?
  • How to link two audio tracks so that key frame work applies to both ?
    Posted by Alexandre Brandt on August 21, 2013 at 3:05 pm
    Hello folks,
    Coming from FCP I was used to be able to change levels of audio with key frames on 2 mono clips which were linked. One change would apply to both when linked. I now have in my Premier Pro CC timeline 2 stereo tracks that are linked and that I paned (L & R) all the way. Is there a way to play with keyframes on one and have them apply to both clips/tracks ?
    Thanks !
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Ivan Myles replied 12 years, 9 months ago 2 Members · 3 Replies
  • Ivan Myles
    August 22, 2013 at 3:58 am
    Create a submix track, open the Audio Mixer, and change mapping for the two desired tracks from “Master” to “Submix 1”. You can then insert keyframes directly on the submix in the timeline panel.
  • Alexandre Brandt
    August 22, 2013 at 2:46 pm
    Thank you Ivan.
    Would that workflow compromise things down the line such as OMF exports ? Indeed, my project will be fine mixed by a sound designer. I will bring a OMF. Does making submix generate problems down the road if we work in other software such Pro Tools ? Thanks
    -> FILMMAKING !
  • Ivan Myles
    August 22, 2013 at 8:24 pm
    I do not have experience with that workflow; perhaps others can comment. Try processing a short test file to identify any issues.
