Activity › Forums › Adobe After Effects Expressions › how to link one layer to another, so they move together on the time line
  • how to link one layer to another, so they move together on the time line
    Posted by Adi Arusi on January 24, 2016 at 11:58 am
    Hello folks,
    I’m Using Templater Plug-in for AE (working on AE 2015 cc), I have footage files that change daily, and so their duration is different every day.
    I have an transition layer that is always above my footage file layer.
    How can I link that transition layer to the footage outpoint layer that changes daily so that they will always move together?
    I found this expression-
    But is effects only the inpoint of the transition and it doesn’t effect the footage layer under it.
    target=thisComp.layer(“A”); // where ‘A’ is the footage layer to link the video to
    time-target.inPoint
    I also added a screen shot which explains the problem, Maybe it’ll help
    Adi.
    Adi Arusi replied 10 years, 8 months ago 2 Members · 2 Replies
  • Miguel De mendoza
    January 24, 2016 at 2:41 pm
    You cant`t change a layer outpoint via expressions, you must do it by script. But if you only have to do it once per day, the best way is mouse+shift.
  • Adi Arusi
    January 24, 2016 at 3:23 pm
    thank u
    the layer out point change automatically when templater script is apply
    and import a new footage white different duration.
    the problem that i have a lot of changing footages that each one have transition and i need this transitions above will be link to each one of them
    this expression:
    target=thisComp.layer(“transition”); // where ‘transition’ is the footage layer to link the video to time-target.outPoint
    moving the “transition” layer to start right after the new footage white the new duration
    but it need to start something like 5 second before the outpoint for the transition effect and this is my problem…
