Activity › Forums › Adobe After Effects Expressions › How to link a keyframe to a slider control
  • How to link a keyframe to a slider control
    Posted by Ramon Peppelenbos on January 27, 2015 at 5:05 am
    Hey all,
    I want to do something fairly simple:
    Got 2 keyframes on the opacity of a layer
    The first keyframe has a value of 0
    The second keyframe has a value of 0
    Now I want to be able to control the second keyframe with a slider control. So when the slider value is 50, the keyframe value is 50 (so the animation will be from 0 to 50). is there a keyframe index that I can use to link it up with a slider control? and in a way where I can simply change the slider and everything will update without issues?
    I’ve found expression that does the trick, but they seem way too complex for my situation and I have no idea what’s going on here:
    keyNumToChange = 3; //change this - the key num to change (numbering starts at 1)
    newVal = [1500, 460]; //change this - the new position.
    nearKey = thisLayer.position.nearestKey(time).index;
    lastKey = (thisLayer.position.key(nearKey).time>time) ? ((nearKey>1) ? nearKey-1 : nearKey) : nearKey;
    nextKey = (lastKey
    I would love to understand how this expression works, but primairly I'd like to know to write something a little more simplified (if possible) and how it exactly works.
    Thanks in advance
    Regards,
    Ramon Peppelenbos
    Suraj Perera replied 5 years ago 5 Members · 5 Replies
  • Dan Ebberts
    January 27, 2015 at 7:23 am
    I think an opacity expression like this would do the trick:
    if (numKeys > 1){
    t1 = key(1).time;
    t2 = key(2).time;
    v1 = 0;
    v2 = effect("Slider Control")("Slider");
    linear(time,t1,t2,v1,v2);
    }else
    value
    Dan
  • Ramon Peppelenbos
    January 27, 2015 at 7:49 am
    Thanks a lot, does the trick. Could you perhaps explain how this exactly works?
    Not familiar with numKeys, key().time and how linear() works in combo with that. Or perhaps you got some resource I can read to fully understand what’s happening
    I’ve also noticed there is no real way to easy eaze, has that something to do with linear?
    Regards,
    Ramon
  • Amit Patel
    February 2, 2015 at 5:45 pm
    It would be great if you can explain same expression for Position, rotation and scale. You are Great !
  • Igor Repin
    June 7, 2017 at 12:35 pm
    Hi there! It’s really helpful! Is it possible to add to this script a inertial bounce? I tried to combine two scenarios, but this was unsuccessful.
    if (numKeys > 1){
    t1 = key(1).time;
    t2 = key(2).time;
    v1 = 0;
    }else
    value
  • Suraj Perera
    September 2, 2021 at 12:33 pm
    Amazing and very helpful for me.. Thank you so much !
