Activity Forums Adobe Premiere Pro How to limit.avi file less than 4gig?
  • How to limit.avi file less than 4gig?
    Posted by Pengchon Vann on June 4, 2010 at 9:52 pm
    Everytime I export my video to .avi, the video comes out between 5gig to 7gig. This is under DV NTSC codec.
    What can I do to limit it to 4gig so I can put it into a DVD as data disk?
    Pushpanatha De silva replied 16 years, 3 months ago 3 Members · 2 Replies
  • Jeff Pulera
    June 5, 2010 at 12:48 am
    If you must encode to the DV codec, then the data rate is fixed – the only way to get a smaller clip is to shorten the video. Split the clip in two and render two parts and use two discs, don’t know what else to say
    Jeff Pulera
  • Pushpanatha De silva
    June 5, 2010 at 8:55 am
    Or use a double layer DVD, so that u can record up to 8Gb worth data…But ur DVD writer should have have a double layer write facility.
