Activity Forums Adobe Photoshop How to limit cut-put tool to fix ratio
  • How to limit cut-put tool to fix ratio
    Posted by Juergen Jerzembeck on July 20, 2006 at 9:18 pm
    how can i force the cut-out tool to a fix size, e.g. 2:3, regardless of width*hight and pixel.
    If I add values in the fields for width and hight, the software defaults always to a measure (inch or cm).
    Giorgio
    Erik Wright-olsen replied 20 years, 1 month ago 2 Members · 1 Reply
  • Erik Wright-olsen
    August 3, 2006 at 5:32 pm
    In Photoshop? I usually use the marquee tool first. With that, you can select a fixed aspect ratio. When I have the marquee tool as I want it, then I use the Crop item in the menu, not the crop tool.
