Activity Forums Adobe After Effects How to key only out-of-focus area
  • How to key only out-of-focus area
    Posted by Heath Franklin on June 6, 2013 at 2:06 pm
    hi all, i have an image that has a foreground in focus and background out of focus. is there a quick way to key the out of focus area so i can manipulate it only? obviously i don’t want to rotoscope. i’m wandering if there is a way to mimic how a camera determines focus by identifying contrast between pixels. thanks for the help.
    Sam Freeman replied 13 years, 3 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    June 6, 2013 at 5:18 pm
    Roto Brush may do the trick – it does take a bit of work but it’s worth the time.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Heath Franklin
    June 6, 2013 at 6:55 pm
    thanks but roto brush will be VERY time consuming and i don’t know that it would work. i have a subject with a white shirt in front of a blown-out background. i need to separate to color correct each on its own. the latitude is, amazingly, there but i have to be able to blend them and roto brush is all over the place with the matte due to the white-on-white image.
    it seems like there would be a way to mimic how a camera ‘sees’ contrast to autofocus a lens and use this as a matte.
  • Sam Freeman
    June 7, 2013 at 7:37 am
    I don’t know whether this will help you – I’ve never used it myself but it might help you out?
    https://aescripts.com/efx-uniqueness/
