Activity Forums Adobe After Effects How to keep ram preview loading while switching to another program
  • How to keep ram preview loading while switching to another program
    Posted by Orion Satori on January 11, 2014 at 11:35 am
    I haven’t been able to find any answers to this, but it seems like it should be the default setting. Whenever I’m doing a ram preview, I can’t click on ANYthing, or it stops loading the preview. Do I seriously have to sit there and stare at a scene slowly loading for 10 minutes instead of browsing the internet or something else? Please tell me there’s something in preferences to change this. I can’t find it. Thanks
    Orion Satori replied 12 years, 7 months ago 4 Members · 4 Replies
  • Todd Kopriva
    January 11, 2014 at 6:12 pm
    If those other programs need the RAM, then the operating system is going to take it from After Effects and give it to those other programs.
    In general, you should have a separate computer (like a cheap laptop) for things like email, web browsing, music, et cetera. Then you won’t have problems with these peripheral programs taking resources away from your main working applications on your worksatation.
    That said, check your Memory & Multiprocessing preference settings in After Effects and make sure that your RAM distribution is such that other applications are being allocated an adequate amount of RAM.
    After Effects team blog
  • Philip Bowser
    January 11, 2014 at 6:19 pm
    I agree with you, that is a little annoying. I’m not sure if you’re on a Mac or PC, but I’ve been able to switch programs by pressing Command + Tab without After Effects stoping a ram preview on my Mac. Or by using the dock to switch apps. However you are correct that After Effects will stop a ram preview if you click anywhere inside of AE. It would be great if there was a preference setting to tell After Effects to only stop the rendering of a ram preview if you press the stop button or it’s associated hot key. That way an accidental mouse click doesn’t halt a render.
    Perhaps there is a reason for it being this way that I am not thinking of..
    Philip. Bowser
  • Roland R. kahlenberg
    January 12, 2014 at 4:45 pm
    Are you previewing via the spacebar instead of the 0 key on the numeric keypad?
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Orion Satori
    January 20, 2014 at 4:00 pm
    Awesome! That works (hitting 0). Thanks!
