Activity Forums Adobe After Effects How to join two Shape points on a layer?
  • How to join two Shape points on a layer?
    Posted by Stephan Dube on May 27, 2008 at 3:06 pm
    Hello,
    This would be very easy to explain with a picture but unfortunately I can’t find a way to upload a picture on here 🙁
    My question is the following: I have created a Shape layer insdie of AE, now on that shape layer I have created a thick frame around a picture thep roblem that Im having is that since Im using a blending mode (multiply) you can see the stroke where I started the frame and where it ends. There is a stroke in the middle of the frame, is there a way I can combine two anchor points into one? if so how do I do this?
    thanks
    Stephan Dube replied 18 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
