Activity Forums Apple Final Cut Pro Legacy how to interlace good?
  • how to interlace good?
    Posted by Larissa Goerner on August 29, 2008 at 12:41 pm
    Hi there,
    i have a problem with INTERLACING, as i have to interlace (not de-interlace) 720p material to 1080i.
    How to do that best?
    there is a preset in compressor fpr 1080i but it works really bad.
    whenever there ist motion in the picture it starts to jerk or studder (i hope u know what i mean with that).
    what is the setting point for interlacing?
    can i control that anyhow?
    what does final cut do to interlace (just throwing lines away?)
    there are a lot of coding artefacts.
    please help me on this.
    all the best
    larissa
    Jeremy Garchow replied 18 years ago 4 Members · 4 Replies
  • Walter Biscardi
    August 29, 2008 at 12:45 pm
    [Larissa Goerner] “i have a problem with INTERLACING, as i have to interlace (not de-interlace) 720p material to 1080i.
    How to do that best? “
    AJA Kona 3. Does this in realtime as you lay out to tape. We do this all the time including taking 1080i to 720p.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Larissa Goerner
    August 29, 2008 at 1:09 pm
    and what if i had no aja kona 3?
  • Rafael Amador
    August 29, 2008 at 1:38 pm
    Hi Larissa,
    A good re-interlacing is not an easy and fast task. You need to re-create half of the picture.I don’t know how Compressor do it when you activate the best setting etc.
    I’ve done it with Twixtor and Re-Vision FieldsKit. The result is outstanding but it takes time.
    Basically with Twixtor you duplicate the number of progressive frames by interpolating new pictures. To create those new picture with quality takes time.
    FieldsKit just take a half of the lines from each frame.
    Lately I tried with Motion the picture duplication. In Motion I can do it in 32b and exportb 10b Unc or ProRes. In FC my old Twixtor version works only in 10b.
    rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    August 29, 2008 at 3:14 pm
    Why do you have to reinterlace? Why not go 1080p?
    I should ask, what frame rate is your 720p footage?
