Activity Forums Avid Media Composer How to incorporate clean externally recorded audio into a multi-clip
  • How to incorporate clean externally recorded audio into a multi-clip
    Posted by Frank Raposo on June 3, 2012 at 7:47 pm
    Hi all,
    I have to create some grouped multi-clips but none of the cameras have clean audio. The good audio was recorded separately on a zoom recorder. I know how to create the multi-clip but how do I incorporate the clean audio into the multi-clip so that entire group is using the clean audio when I cut back and forth? Thank you.
    quinnmcguee
    Richard Sanchez replied 13 years, 11 months ago 2 Members · 1 Reply
  • Richard Sanchez
    June 3, 2012 at 7:59 pm
    I usually autosync the clips first, and then multigroup them. On my current show, we’re running a multitrack recorder with mixdowns on channels 1 and 2, and feeding that mixdown to channels 1 & 2 on our A cam.
    In my case, the timecode isn’t very accurate, so I’m syncing by audio phase. If your timecode sync is good, then you can autosync by source timecode. In my case, I go down the timeline, matching back to the clips, adding an in point and using autosync by in point. If you’re using MC 5 or newer, there’s an option to include a range of tracks. In this case, I only give the editors the mixdown tracks, which is all they need about 90% of the time. If they need to get the isos, they can match back into them and pull them out, but it makes the tracks easier to work with than have 8 tracks of audio attached to them.
    Autosync will take your audio master clip, and your video master clip and create a new sublcip, with “.sync” appended. You can group or multigroup that sublcip like normal after that.
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
