Activity › Forums › Adobe After Effects › How to improve an old film
Posted by Ryan Castle on November 10, 2011 at 10:50 pmHow can I remove film grain, and make the quality and details better on an older film?
Chris Wright replied 14 years, 10 months ago 3 Members · 2 Replies -
Angelo Lorenzo
November 10, 2011 at 11:55 pmI suggest Magic Bullet’s denoiser for grain/noise removal https://www.redgiantsoftware.com/products/all/magic-bullet-denoiser/
It’s probably one of the slowest rendering effects I own, but the quality is worth it.
Granted there are some techniques to reduce noise including After Effects built-in noise removal plugin (an adaptation of a well known software Adobe bought, Grain Surgery) but I prefer something a little more dedicated.
In terms of “better quality and detail”… this is super vague, but old video always benefits from a little color re-mastering. You can use a combo of After Effects built in curves and other color correctors, or pick up Colorista Free which is a free three-way color corrector https://www.redgiantsoftware.com/products/all/magic-bullet-colorista-free/
*I’m not affiliated with Magic Bullet, I just think a lot of their plug-ins are awesome.
Angelo Lorenzo
https://filmsfor.us – Helping you sell your film online
Watch Steve Job’s Spirit Inside The iPhone 4SSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Chris Wright
November 11, 2011 at 7:35 amauto white balance, auto flicker remover, and shadow restorer just set the gamma clamp so that the top text layer(its off default) shows 25. then the flicker gets removed plus the shadows repaired. I’ve used it on some destroyed 8, 16mm stuff, and it works perfect.
ae cs3 aep
https://www.mediafire.com/?fz0s3i85a45ou58it uses AE’s shadow highlight effect automatically. you can use it manually on your own, too. More things you can do are AE’s remove grain then the unsharp effect. finally, some technicolor put back in because technicolor footage often gets washed out.
AE cs3 technicolor
https://www.mediafire.com/?5aerw1p7gejahsaor tiffen’s dfx. also, red giant has good color correction, and color finesse comes with AE.
