Activity › Forums › Adobe Premiere Pro › How to Import video only, no audio.
  • Tero Ahlfors
    October 30, 2016 at 5:03 pm
    When you import a file it is linked in Premiere so if the source file has audio then it will show up. That said you don’t have to use the audio. You can use the mouse and drag only the video to your timeline or if you deselect track targeting for audio then your edit won’t use the audio tracks.
  • Dave Wilson
    October 30, 2016 at 6:26 pm
    Well I did end up just muting the tracks I didn’t want. But that can be a lot of wasted real estate. And going in and unlinking the audio from the video then deleting can be quite time consuming. Just seems like something common enough that there would be an option for it.
    Dave Wilson
    http://www.secondsightstudio.com
  • Tero Ahlfors
    October 30, 2016 at 7:36 pm
    What exactly are you doing that would need you to not use any audio and taking off the audio targeting from the sequence isn’t enough?
  • Dave Wilson
    October 30, 2016 at 7:52 pm
    I’m importing dozens and dozens of clips that are being set to music so I don’t need any of the audio from the video itself.
    Maybe I’m not sure what you mean by taking off the audio targeting…And as I typed that I realize yeah, I haven’t got a clue what you mean.
    Dave Wilson
  • Tero Ahlfors
    October 30, 2016 at 9:04 pm
  • Duke Sweden
    October 31, 2016 at 12:17 pm
    You see the source monitor? See at the bottom there’s a film strip icon and a sound waveform icon? If you click on and drag the video IMAGE, both video and audio will appear on the timeline. If you grab the film strip and drag, only the video will appear on the timeline. If you grab the waveform and drag, only the audio track will appear on the timeline.
  • Jon Doughtie
    October 31, 2016 at 12:59 pm
    Alternatively, select ALL clips you do not want audio for in the bins.
    Right-Click and select “Modify–>Audio Channels”
    Change the “number of audio tracks” to zero. Save that setting with a name of your choice. (I called mine “No audio, please!”)
    You have now globally changed it for all selected files. When you pull them into the Source monitor or timeline, you will have no audio tracks at all.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Jeff Pulera
    October 31, 2016 at 2:56 pm
    Put your clips on the timeline. Either click/drag mouse to select all clips or CTRL A, then right-click and UNLINK. Now click/drag to select/highlight just all the audio clips. DELETE. Simple, takes 2 seconds.
    Jeff Pulera
    Safe Harbor Computers
  • Duke Sweden
    October 31, 2016 at 2:58 pm
    Well, yeah, sure, if you want to do it the easy way. Pffffttttt… 😉
  • Dave Wilson
    November 1, 2016 at 1:32 am
    Jon! That’s awesome! Thanks! Still think there should be a video only import option, but this works!
    Jeff, that’s what I was doing at the beginning of my journey. But when you have to do it for a few hundred clips, it gets seriously tedious and time consuming…
    Thanks everyone! Now, if i could only get answers to my other post. hehehe
    Dave Wilson
