Activity › Forums › Adobe After Effects › How to import footage into After Effects from a script?
  • How to import footage into After Effects from a script?
    Posted by Mario Gomes on December 29, 2011 at 1:44 am
    I need to write a jsx script that imports footage into an after effects project. I can’t find any information about this. Anyone knows how this can be done?
    Hayden Klabunde replied 11 years, 6 months ago 4 Members · 3 Replies
  • John Cuevas
    December 29, 2011 at 4:48 am
    I don’t write scripts, but the first place I would check is the expressions forum here and wait for Dan Ebberts to reply.
    He also has some scripting stuff on his webpage:
    https://www.motionscript.com/
    Finally there is a 5 part tutorial on AE tuts you might want to check out:
    https://ae.tutsplus.com/tutorials/workflow/introduction-to-writing-scripts-for-ae-expressions-day-1/
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Kaspar Gio
    June 21, 2013 at 10:14 am
    For my own script I imported multiple tiff-sequences with this:
    var path = "~insert your filepath here ~";
    var io = new ImportOptions(File(path));
    if (io.canImportAs(ImportAsType.FOOTAGE));
    io.importAs = ImportAsType.FOOTAGE;
    // if your footage is an image-sequence:
    io.sequence = true;
    io.forceAlphabetical = true;
    tiffseq = app.project.importFile(io);
    tiffseq.name = 'My automatically imported foorage";
    theComp = app.project.activeItem; //currently selected composition(example)
    theComp.layers.add(tiffseq);
    Hope it helps!
    Layout/compositor for Animation show.
  • Hayden Klabunde
    April 1, 2015 at 7:50 pm
    Hello:
    I’ve used your script and was able to import a single image and import an image sequence. Is it possible to import an image sequence using file names within an array?(The files are contained within the same folder and I need to call the files multiple times.)
    var myFileArray= new Array(“file.ext”,”file.ext”,”file.ext”);
    var path = “~/Desktop/Folder/”(myFileArray);
    io.sequence = true;
    io.forceAlphabetical = false;
    tiffseq.name = “File Name”;
    alert(“Image Import Complete”);
