Activity Forums Avid Media Composer how to import audio on avid xpress dv?
  • how to import audio on avid xpress dv?
    Posted by Bombonia on May 15, 2006 at 6:14 am
    hi
    and first of all thank you for being there..
    here:
    10.4.6
    450mz G4
    1.17 Gb sdram
    avid xpress dv
    i am trying to import an audio file aiff into my project, and i get a -35error sign.
    what should i do?
    Best,
    bombonia
    Bombonia replied 20 years, 3 months ago 3 Members · 4 Replies
  • Michael Phillips
    May 15, 2006 at 10:23 am
    Can you get a WAV version of the file and try that?
    anything 24fps
  • Bombonia
    May 15, 2006 at 3:34 pm
    do mean that the audio file should not be an .aiff in order to be imported into avid xpress dv??
    then, what should i do to get a WAV out of the .aiff?
    (thank you so much)
  • Randy Pfeiffer
    May 16, 2006 at 12:25 am
    You could download “Audacity” here https://audacity.sourceforge.net/ (what I use) or other free sound editor and convert your audio file to “.wav” format and import…
    HTH,
    Randy
  • Bombonia
    May 16, 2006 at 4:52 am
    It worked out.
    thank you so much.
    i hope i won’t have any problem when exporting the sequence… i don’t know how i’ve done it in the past, but surely not this way…
    again, thanks for your time and interest.
    bombonia
