Activity Forums Apple Final Cut Pro Legacy How to import a clip that is recorded across two SXS cards in its entirity?
  • How to import a clip that is recorded across two SXS cards in its entirity?
    Posted by Liam Morgan on April 22, 2008 at 11:22 am
    How does one deal with this situation of putting back together the two halves of a clip that was recorded at the end of one SXS card and continues on to the other? Must I import the two halves separately and line them up in FCP, or is there a better way?
    Liam
    Zak Mussig replied 18 years ago 3 Members · 3 Replies
  • Liam Morgan
    April 22, 2008 at 11:24 am
    please disregard my spelling…
  • Walter Biscardi
    April 22, 2008 at 12:10 pm
    [Liam Morgan] “Must I import the two halves separately and line them up in FCP, or is there a better way?”
    Yeah, that should be easy assuming the first card stops at the end of a timecode and the second card picks up where that one left off.
    Just line them up in a timeline head to tail. There might be an overlap of a few frames, but just chop those off the head of the incoming clip.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Zak Mussig
    April 22, 2008 at 3:21 pm
    Liam,
    Sony’s transfer software will combine the two parts into one file. You need to mount both cards (or add both BPAV folders you’ve moved to hard drive as sources) and use the transfer app to export the complete clip.
    From Sony’s XDCAM Transfer User Guide:
    “When the selected clip is in XDCAM EX format, and has
    been split within a single SxS memory card because of file
    system limitations, or when it has been split and recorded
    across multiple SxS memory cards, the smaller clips into
    which the original clip is split are called “child clips” in
    this help. In XDCAM Transfer, these child clips are
    displayed as subclips and can be handled in the same way
    as subclips (except that they cannot be deleted)”
    Hope that helps,
    Zak
