Activity › Forums › Apple Final Cut Pro Legacy › How to I get my Quicktime movie on the web?
Posted by Simon Malcolm on December 16, 2005 at 7:59 amHi there, I have made a 3 minute movie in FCP 5 and want to send it to someone to put on a website. He has asked me for an mpg file which does not exceed 2MB. There doesn’t seem to be any way to export from FCP 5 that will allow me to create a file that doesn’t rely on the end user having QuickTime 7. What do I do?
Matt Murray replied 20 years, 9 months ago 6 Members · 5 Replies -
Shane Ross
December 16, 2005 at 9:08 amAn MPEG file is a quicktime file. Quicktime is a “wrapper” for the MPEG codec.
Shane Ross
Alokut Productions
http://www.lfhd.net -
Tim Vaughan
December 16, 2005 at 12:03 pmWhat we usually do is in FCP, go to file–>export–>using Quicktime conversion. Set your Format to Quicktime Movie, and “Use” to either 300k, 1400k, LAN, etc depending on your file limitations. Or, open Quicktime Pro, import your finished movie, Click on Export, and set it to Quicktime Movie, using again the internet settings that drive you wild!
Hope this helps.Tim
Tim
Craig Seeman
December 16, 2005 at 2:54 pmIf you have FCP5 than you should have Compressor 2. Export a Quicktime Movie (self contained or reference). Put that in Compressor and start with a preset. Duplicate and alter settings to your desire. Read the PDF Compressor manual.
Bryce Whiteside
December 16, 2005 at 5:18 pmJust about any encoding you can do in QuickTime Pro individually you can create presets in Compressor. That way you can adjust the parameters in the new presets until you get your desired 2MB file. You can then batch encode your FCP timeline in Compressor for the right combination of quality and file size–i.e. you are encoding the same file with different encode settings unattended from wihtin Compressor’s batch mode.
https://freevlog.org/#compress and click on Final Cut Pro
FYI,
Bryce WhitesideDon’t worry Mr. B. I have a cunning plan…
PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
Final Cut Pro HD
DVD Studio Pro 3
Motion -
Matt Murray
December 17, 2005 at 12:38 pmGoing to be hard to get a decent quality movie of 3 minutes length under 2 megs.
I just checked one of the websites that I manage, and the news is pretty grim.QT movies vary, but here are the basics of what I have on the site.
30 seconds, QT movie, 320×240 1.6 MB
30 seconds AT movie 240×180 724KB
1 minute 56 seconds QT movie 320×240 6.6 MB.You can view the samples here
https://www.edgesportfishing.com
Click on the “videos” link.
Matt Murray
Lineside Productions
Wellington, FL
Florida Sailfish videos, pictures and moreMac OS X 10.4.1 , QT 7.0 Dual 2.5 GHZ, 4 gigs RAM, 23″ HD display, JVC BR-3000 deck, 5 120 gig LaCie Firewire Drives, JVC 17″ H1700 NTSC monitor, FCP HD 5, DVDSP 4, Compressor 2.0, Motion 2.0
Soundtrack Pro 1
