Activity Forums Adobe After Effects How to Hide some Part of the clip and replace it with something else
  • How to Hide some Part of the clip and replace it with something else
    Posted by Taha Kirmani on January 10, 2011 at 9:08 pm
    Hello
    I created a video ,that a Man is running on Playground , and suddenly he hit by a stone and fall into the floor .
    The problem is that , when Man hits the floor , he lay into the Red Color Badsheet ,not into the sand , because he did not wanted to lay on the Ground and get dirty .
    The Problem is that my camera is moving alot , if i use Masking , i think i need to create couple of masks , and i need to rotate them alot .
    Is there any other way to do this .
    Regards,
    Taha .
    Todd Kopriva replied 15 years, 7 months ago 2 Members · 1 Reply
  • Todd Kopriva
    January 11, 2011 at 1:56 am
    That is normal. Rotoscoping is complex, tedious work.
    Just for comparison, I recently had to rotoscope to separate a man’s upper body from a background, and I had to use eight masks to to it, each animated frame by frame. And that was a simple shot, since his lower body was blocked by a desk.
    There are many ways to separate a foreground subject from a background. The most common ways are listed here:
    “Compositing overview and resources”
    The ones that aren’t a lot of work (such as color keying) take a lot of planning and discipline during shooting.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
