Activity › Forums › Adobe After Effects › How to hide a value under the transform?
  • How to hide a value under the transform?
    Posted by David Hall on August 18, 2015 at 1:11 am
    I’m trying to hide the values that I don’t use but it doesn’t work when I select them and press delete.
    How can I delete “anchor point” “position””opacity”?
    Spencer Tweed replied 11 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Spencer Tweed
    August 18, 2015 at 3:32 am
    You want to get rid of them entirely? Not possible… However if you hit the shortcut for the item while holding down Shift and having the layer selected, they will be toggled on and off. Try shift+T to hide the opacity, for example.
    Anchor point is “A” position is “P” and opacity is “T”
    – Spencer
  • David Hall
    August 18, 2015 at 4:45 am
    Awesome, it works.
    How did you discover this stuff?
    Could you please recommend a great book to learn AE?
    Love it so much.
  • Michael Szalapski
    August 18, 2015 at 8:27 pm
    That kind of stuff is covered in the resources linked here: https://adobe.ly/AE_basics
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Spencer Tweed
    August 19, 2015 at 5:12 am
    Experience and watching millions of tutorials! The best introduction is VideoCopilot’s basic training tutorials:
    https://www.videocopilot.net/basic/
    I try to watch a tutorial and then find a different project to apply what I learned to. Or if I go to start on a project and I’m not sure how to do it I’ll usually surf around to find a tutorial for something similar, and then figure out how to adapt it to what I want to do. As far as the small tips and tricks – you pick those up over the years. For example want to set a keyframe on any property that has a shortcut? hold shift+alt like shift+alt+p to key the position of a layer. That’s a totally random tip I heard on a tutorial years ago, and I just used it in a project 5 minutes ago!
    Also, I’ve read the whole AE manual through digital cover to digital cover. It took me a few weeks but it was well worth it.
    – Spencer
  • David Hall
    August 19, 2015 at 5:38 am
    Thanks for your warm haerted and helpful replay.
    So happy finding an awesome play and meet you awesome people here.
  • David Hall
    August 19, 2015 at 6:55 am
    Hi, I’ve encountered another problem about this.
    I was trying to hid mask opacity but I can’t find its shortcut anywhere.
    Any solutions about this?
  • Walter Soyka
    August 19, 2015 at 3:28 pm
    [David Hall] “Hi, I’ve encountered another problem about this.
    Any solutions about this?”
    You can temporarily hide any property whether it has a shortcut or not by Alt+Shift+clicking the property name in the timeline panel.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Spencer Tweed
    August 20, 2015 at 9:56 pm
    That’s cool, never knew about that trick!
    The shortcut for mask opacity is “TT”. Unfortunately when trying to hide it you will also toggle the layer opacity…
    – Spencer
