Activity Forums VEGAS Pro How to get this to 50 meg or less (and still able to view captions well)
  • How to get this to 50 meg or less (and still able to view captions well)
    Posted by Amanda Duffield on April 26, 2017 at 7:02 am
    Hello all,
    I have a 10 min excerpt from a TV show – details are below. I need to compress down to 50mg or less to fit on our shared area (yes, copyright is sorted with users having to click through various acknowledgments). It does have captions (burned in from broadcast) so needs to stay clear enough for them to be readable, but other than that, no real stipulations other than size.
    I have SVP13 and Handbrake.
    Thank you very much ☺
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 405 MiB
    Duration : 4mn 25s
    Overall bit rate mode : Variable
    Overall bit rate : 12.8 Mbps
    Encoded date : UTC 2017-03-02 09:58:25
    Tagged date : UTC 2017-03-02 09:58:25
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Format settings, GOP : M=4, N=15
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 4mn 25s
    Bit rate mode : Variable
    Bit rate : 12.6 Mbps
    Maximum bit rate : 24.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.243
    Stream size : 398 MiB (98%)
    Language : English
    Color range : Limited
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 4mn 25s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : channel0
    Channel(s)_Original : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 6.08 MiB (2%)
    Language : English
    Steve Rhoden replied 9 years, 4 months ago 5 Members · 6 Replies
  • Steve Rhoden
    April 26, 2017 at 10:19 pm
    Try using the Vegas to Handbrake Script and render out as mp4 through Handbrake:
    Excellent results with very small file size output…
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Amanda Duffield
    April 27, 2017 at 11:12 am
    Thank you so much. Sorry to sound obtuse but i don’t know skewewhere to get that? Do i download it?
    Thanks again
  • Wayne Waag
    April 27, 2017 at 10:07 pm
    You’re probably too late since the author has removed it from his website. it used to be here.
    https://www.vegasvideo.de/vegas-2-handbrake-en
    wwaag
  • Marco Baer
    April 28, 2017 at 12:54 pm
    Actually I didn’t remove that certain page but my whole VegasVideo.de website is down since end of 2016 due to some server modifications which are not compatible with the CMS version I used for creating the site.
    You could still access the page via a web archive:
    https://web.archive.org/web/20161013201440/www.vegasvideo.de/vegas-2-handbrake-en
    But you should know that the description and the linked files doesn’t take care of the changes made to the scripting language since Magix took over, also it is not modified for the use of the current HandBrake version. What you’ll find on the web page is meant for the use of the Sony branded versions of Vegas Pro 11 to 13 and HandBrake before version 1.0.
    I had to stop updating Vegas2HandBrake because meanwhile there are too many variations of Vegas Pro and other tools involved with each would need own modifications. I once made this workflow for my own use only and my limited time does not allow anymore to trace each of the tools involved, doing the modifications needed and updating files and descriptions, sorry.
  • Graham Bernard
    April 28, 2017 at 1:25 pm
    Thanks Marco.
    * Grazie
  • Steve Rhoden
    April 28, 2017 at 9:30 pm
    Great, you provided the link Marco….
