Sorry, I, like Dave took it as the text resolve you were looking for.
The Emma Watson fade is two elements (or more). The background comes in first with Emma (as a separate layer) on green screen and keyed or rotoscoped, holding as a silhouette before she is brightened. She may have interactive lighting on her that was shot on set or there was some color correcting with masks done to brighten different parts of her before others.
The front elements are another layer – either shot out of focus (this is called “bokeh”) or done with a filter like Lens Care’s Frischluft so you can animate the amount of out of focus – AE’s Lens Blur can sort of do this but no where near as well.
All of these elements are done as 3D layers placed at different depths and the camera is pulled back through them to get some parallax and depth – things farther from the camera recede more slowly than things close to camera. (or they are all flat layers at the same level and scaled in concert to give the multiplane camera effect)
If you are going to color correct down to a silhouette, in other words, a severe crushing of the levels, use a high color depth comp (16 or 32 bit) so there is lots of head room when you start pushing those sliders around, otherswise colors will band and oversaturate. Also try putting a desaturate (HSB effect) before your color correct in the effects stack so that crushed colors don’t bloom and posterize.
