Activity › Forums › Panasonic Cameras › how to get the best quality on P2 card
  • how to get the best quality on P2 card
    Posted by Tamir Bassal-tana on February 14, 2009 at 1:11 pm
    Hi
    I am going to rent HVX-200 or AG-HPX500
    now i love the quality of Digital Betacam and basically i want to get the same quality with the use of the P2 card so that i will not need to work with Digital Betacam tapes.
    but as i have understand if i will work in any format that is above DV then i always have a problme that i need to downconvert the material to standard DEF as my finel product is always a standard DVD
    so i have no use of the High DEF as i will not make any High DEF DVD
    and from forum on the net i can only see that people complain that the material on the Edit bay looks wonderful but when you send it to a DVD the quality is not as good as if you have send a Digital Betacam material , as in DV and in Digital Betacam you don’t have any problems to change the frame size or any setting as you only need to change it to mpeg2 and this is the only compression yoy do.
    so my question what format do i choose from to get the best quality and not to have any problems with the change to mpge2 i work with Avid Media Composer 3.1
    and that sad if i do need to work with High DEF who do i work in a way that will not give me any problems to go to mpeg2 and still have the same good quality as the master material
    Shane Ross replied 17 years, 7 months ago 3 Members · 5 Replies
