Activity Forums Adobe Photoshop How to get rid of background cracks
  • How to get rid of background cracks
    Posted by Russell Levenson on June 14, 2010 at 7:50 pm
    Okay so I’m dealing with a picture of a tree. The whole background is white and I need to get rid of the thousands of little white background areas in between the leaves. Is there a way to sample the value white and then delete the rest of the white in the picture? Thanks.
    Christina Rodriguez replied 16 years, 2 months ago 4 Members · 3 Replies
  • Paul Benson
    June 17, 2010 at 1:41 am
    Magic wand with the non-contiguous option is the poor man’s choice.
    Select Color Range is likely what you want. Plenty of tuts on the net about it.
    Pauley
  • Jochem Baron
    June 17, 2010 at 6:41 am
    You could also use the background eraser tool. Search for a tutorial on google.
  • Christina Rodriguez
    June 18, 2010 at 11:46 pm
    May I suggest that you work in a mask… I find it to be much more flexible incase you make a mistake…
    Plus, lets say you remove the edges BUT they are too hard… If you Don’t have a mask it will be hard to blur the edges but not the actual image. With a mask, you don’t need to worry about blurring the image, only the mask. It is non destructive.
    And to make it permanent, you can just drag it to the trash and select “Apply Mask”
    C.R.
