Activity Forums Adobe Premiere Pro how to get RGB color corrector back working with YC waveform monitor
  • how to get RGB color corrector back working with YC waveform monitor
    Posted by Eric Brown on December 16, 2012 at 7:05 pm
    so, as many of you are probably aware, Adobe’s latest update killed the RGB color corrector, at least in terms of using it with the YC waveform monitor.
    In this thread ( https://forums.adobe.com/message/4825916#4825916 )
    someone says-
    “Yes it’s a Bug since the 6.0.2 Update. I replace the effect in the premiere plugin directory with the same from version 6.0.1 and it’s working again”
    how can I go about doing this?
    I looked on another machine running premiere 6.0.0, but I am not seeing a plugin for RGB color corrector in C:Program FilesAdobeAdobe Premiere Pro CS6Plug-insCommon
    and I don’t know what “RGBColorCorrector.cubin” is in C:Program FilesAdobeAdobe Premiere Pro CS6PTXcubin11
    bottom line is that I want the RBG CC back working with the YC waveform monitor again.
    Eric Brown replied 13 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
