Activity › Forums › Adobe After Effects › How to get real Live Update with Color Curves ?
  • How to get real Live Update with Color Curves ?
    Posted by __peter__ on February 5, 2010 at 8:34 pm
    Hello,
    that’s something that bothered me for a long time already.
    When You click and drag points of the standard AE Curve the image is not updated until You release the mousebutton. You then have to hit the exact point not to create a new point.
    I am heavy using curves and that’s really annoying.
    I want to look at the programmonitor while altering the parameters and not on the curve-window.
    Everything else worls like that.
    The levels slider for example has immediate influence on the picture.
    So can this behaviour be corrected ?
    Or is there another good curves plugin out there that helps with that ?
    Peter
    __peter__ replied 16 years, 7 months ago 2 Members · 2 Replies
  • Joey Foreman
    February 5, 2010 at 9:18 pm
    Seems to be a limitation of the plugin. Color Finesse has live update of curves.
  • __Peter__ Create COW Profile Image
    __peter__
    February 6, 2010 at 11:53 am
    Yes! Great. I did’t know color finesse can be used without their big window interface. That’s a good solution. Thanks!
    Hopefully it will still be bundled with AE when CS5 comes out. Which means they also have to provide a 64Bit version.
    Thanks again!
    Peter
